What this error means? OSError:[Errno 13]
When I run my Abaqus it says OSError:[Errno 13; What does this means? Can any1 please advice me?
Jana
RE: What this error means? OSError:[Errno 13]
After checking my Glorious Optimal Option Generating Learning Equipment It seems like its a permission error?
Found this:
"I figured out the reason for the error.  I didn't have permission to
save to/modify files in the current working directory.  I had to
change to another working directory. "
This was for "Abaqus/CAE 6.8-2 Job Error" so not sure if that solves your problem?
Jeffery V C.E.T.
"If Brute force doesn't solve your problem, your not using enough"
