Small scale, product grinder
I have a product that is very staticy, and has a very low bulk density.  Basically cotton balls look like gravel compared to my product.
Can anyone think of a lab, table top sized unit that might be good for grinding this?
What I'm thinking is a vacuum blower connected to a cyclone that pulls through the bottom of a hammer mill.  The bags/cyclone can be pulsed with air to drop the product out.
But I'm not sure if this would work with such a low bulk density, and the static.
RE: Small scale, product grinder
One thought:  Eliminate and control the static with de-ionized air.  Get yourself the static sensor to quantitatively verify the amount of charge on the object.
TygerDawg
Blue Technik LLC
Virtuoso Robotics Engineering
www.bluetechnik.com
tygerdawg, I've never tried that.  Not sure I can do that in the lab.  I wonder if just pumping some deionized air into the container where there product is being held, before grinding could reduce static?
Put it in a home dryer with a dryer sheet.  Tumble a few times or more - see what happens??
Mike,  are those things food safe?
I never ate one - so not sure??!!
I am sure you can read the label or get a MSDS sheet on them which should explain any problems!!
Would it grind in a jet mill?  Use gas to make the pieces hit each other basically.
As for static you could look at humidity control or a small amount of radiation.  Are you old enough to remember the anti-static brushes for you LP's?  They had a small radiation source in them.  It is behind a physical barrier.
Plymouth Tube
