Sketching on a part
Sketching on a part
Sketching on a part
Using Autodesk Inventor 2012 and I came across what should be a very easy question to answer (for experienced users).
When I try to draw on a plane that intersects a solid body, any portion of the sketch that is behind the solid body is hidden from view. The attached pictures shows clearly what I am referring to. In SolidWorks, the sketch normally shows right through the part, is there some design philosophy that I am not understanding with Inventor?
Image Caption:
(left) Indicates where the plane is located
(middle) Indicates a sketch that is fully shown because no portion is behind the solid body
(right) Indicates a sketch that is partially shown and partially hidden by solid body.
Thanks in advance!
RE: Sketching on a part
I found the answer to this problem. Slice Graphics.
Inventor is not AutoCAD.
You are in the wrong forum.
You probably know that I'm well aware of that. They are, on the other hand both manufactured by autodesk. I didn't see an inventor forum so i figured this one was the best fit. Perhaps i'll find the water more inviting at the solidworks forum.
I would have done the same mechfeeney, so there should be no apology.
Thanks man!
