WPQ FOR LOW TEMPERATURE PRESSURE VESSEL USING PD5500
Good day Gents,
pls i need your advise on a WPQ i want to carry out as i am not clear on the Impact energy value requirement for the charpy impact test to be carried out on the test piece.
The WPQ is for a 16mm thk PL, the process to be used for welding this plate is Sub-arc welding(SAW). The presure vessel is to be built in accordance to PD5500 spec, the design temperature of this vessel is -46 deg. C. i have consulted the code and found the ref. point to be ANNEX D Fig D-1 i used the graph in the figure to trace the design ref. temp. down to get the required imapct temp. which falls to be -34 deg. C. where i am have difficulty is to determine the required impact energy value in Joules.
Pls. i need to know if i am on the right path as well as what should be the required impact energy value.
RE: WPQ FOR LOW TEMPERATURE PRESSURE VESSEL USING PD5500
rhg
Please, contact a welding engineer
rhg
