Dry pipe valve in horizontal oreintation
Are there ANY dry pipe system valves designed/approved to be installed in the horizontal position.
We have a very unique challenge........horizontal dry pipe valve would be the best option; however, I cannot find any approved for horizontal oreintation!!
RE: Dry pipe valve in horizontal oreintation
Appears largest is two inch
Existing 6in. DPV.........we need minimum 6 in. diameter. It does not look good at this juncture!
what do you mean in a horizontal position?
1) Are you talking about the discharge coming from the side?
2) Are you talking about both supply and discharge from the sides
Option 2 does not exist for one specific reason.
It would required an extensive engineering and design process that can only to 1 out of 10 applications. No true sale value. Meaning these valve could sit in the warehouse for a while.
I know this because a close friend of mine and regional sales manager for victaulic had that conversation with me years back.
Those with discharges on the side are typically deluge dry valves.
