Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...This is easily the most helpful website I've ever used, and this is the best forum with the quickest response time bar none...."
Geography
IceMan30 (Military)
28 Feb 12 15:13
I have two (2) sets of drag coefficients, purportedly for the same thing. These drag coefficients are used in separate aero models. I know a lot about one aero model, and very little about the other. One thing that stands out to me is that one model uses a constant gravity model, whereas the other uses a varying gravity.
I was wondering if anyone had some thoughts on how I can objectively compare these drag coefficient sets, perhaps using the differing gravity models? Obviously, a simple plot of the two sets shows the differences, but I have this thought stuck in my head that somehow I can better correlate the coefficients, or perhaps the effects of the coefficients, to show how the aero models compare.
Any ideas?
Thanks!
rb1957 (Aerospace)
28 Feb 12 15:17
"varying gravity" ?
if one model has this feature, can you disable it (set it to be constant) and compare the two models ??
btrueblood (Mechanical)
28 Feb 12 15:33
rb,
Have you never tested vehicles up at the Rock?  g decreases with altitude...
rb1957 (Aerospace)
28 Feb 12 16:15
yes, Newton's law F = k*m*M/r^2 ...
the bigger r, the smaller F ...
and, courtesy of wiki "at an altitude of 400 kilometres (250 miles), equivalent to a typical orbit of the Space Shuttle, gravity is still nearly 90% as strong as at the Earth's surface" ... not a very strong effect ...
28 Feb 12 18:02
Nope, not for most missions.  A fraction of a percent on the rock, but it is enough to make a difference, along with lower ambient air pressure, for rocket thrust calcs.
The 10% difference on Shuttle flights was a subject of a long ago conversation in a bar with one of the lads that wrote flight software.  Apparently that correction was included in the HP-41C software for the backup-backup reentry system.
Close Box
Join Eng-Tips® Today!
Join Us             Close
