ABAQUS does not consider my B.Cs from the Input file
Dear all,
I have an UEL and I'm using an input file to address the material and geometry properties. But when I see the results it seems ABAQUS has not addressed the defined BCs and some of BC nodes are free. Here are my command lines:
*BOUNDARY, TYPE=DISP
Clamp-up,ENCASTRE
Sym-Left, XSYMM
Sym-Right, XSYMM
Sym-Bottum, YSYMM
In the msg file I have the following:
COLLECTING STEP CONSTRAINT INFORMATION FOR OVERCONSTRAINT CHECKS
*****WARNING LFLAGS(3)= 4
This warning " *****WARNING LFLAGS(3)= " is defined in the UEL FORTRAN code to show up when LFLAGS(3) is not equal to 1.
Do you have any suggestions? Can I change the value of LFLAGS(3)?
Thanks for your help and time,
Roshanak
Clamp-up,ENCASTRE
Sym-Left, XSYMM
Sym-Right, XSYMM
Sym-Bottum, YSYMM
Roshanak
