Different results for different folks.
Hello, I've an odd issue that has surfaced. We have an engineering assistant in our office that open and exports pdf drawing packages of our products. Recently she opened a drawing and it comes in with dimensions unassociated and the views require to be updated. Even after updating the views the dimensions don't reattach. Any of the drafting employees can open this drawing and it comes in clean with all the dimensions attached. The assembly load options are the same. We are running NX 6.0.5.3 native in windows xp. I'm not sure why there is discrepancy in the pcs. Anyone????
RE: Different results for different folks.
Make sure the engineering assistant has the customer defaults loaded like everybody else does.
Open as saved / from folder / search directories ?
Do they have different disks mapped under the same drive letters and using search directories ?
If not, are the paths ALL in the same order?
Same with reference sets.
Ben Loosli
The customer defaults are confusing I thought if those were changed that was a site wide change and effects all users? Is this not the case?
I can't seem to locate load_options.dat file. on my local drive of the UG server drive.
Load Parents > all levels
Parts to load > Previously loaded
The opening post mentions drawing views not updating and then jumps straight to load options, so I assume it is a master model drawing of a part or assembly, but I'd just like to make sure.
I'd start by checking to see where exactly the parts are loading from; close all open files, open only the file in question on your computer and go to Information -> Part -> Loaded Parts. Save the listing window results to file and/or print it. Repeat the process on the administrator's computer and compare results.
If the same files are loading from the same locations, you can rule out the load options.
www.nxjournaling.com
Yes, mater model method is followed.
