Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...with companys cutting back on training, lack of true support by makers of software, the forums are a great tool in your cyber-toolbox...."
Geography
MidstreamEgr (Mechanical)
28 Feb 12 11:07
I am trying to do some preliminary work on a crude project, and have been warned that the particular crude has exhibited high vapor-pressure properties.
In the lab assays, I have alot of informtion, but no direct RVP or vapor pressure info.  How do I convert to get TVP or RVP?  Useing D86 Distillation data?  Simulated distillation?  Other data?  Just looking for a quick range of VP, to see if I need to anticipate IFR, vapor recovery, etc.
TD2K (Chemical)
28 Feb 12 22:12
What type of lab data do you have?
I've usually used a process simulator to input a D86 or TVP curve with the light end analysis and allow the simulator to develop the crude pseudo-components.  Then you can get the TVP for a given temperature and most process simulators will also give you a RVP.
29 Feb 12 8:46
The lab data is very prolific.  I have a full assay on the crude as well as major cuts.  It's got (for crude) a simulated distillation curve (D7169) and PONAOX(U) analysis.  AS well as the other standard stuff - gravity, viscosity, etc.  What I don't have anywhere is any mention of vapor pressure itself.
See attached distillation curve.
I'm not a chemical or refinery guy - generally I do tank farms.  But i have a client who's talking with a potential customer (who owns the crude) and we're trying to determine if the crude will require any extensive vapor controls.  I've been told by others that if the crude has a TVP at storage temp > 11.1 psia, the storage tanks will need vapor control (combustor, eductor recovery, etc).  Any of these options is more costly than currently planned.  So I'm trying to get a feel if we need to be worried or if this stuff doesn't have enough light ends to worry about.
MarcTroy (Mechanical)
1 Mar 12 3:19
why do not put the crude sample in a closed bottle, remove incondensables (for example by displacing all initial air) control the temperature (electric bath or equivalent system) and measure the pressure in the bottle ?
There are specific (and quite complex) measurement apparatus for both TVP and RVP (see ASTM standards) but I would expect that you may get a realistic value of TVP with the above method.
Close Box
Join Eng-Tips® Today!
Join Us             Close
