Convert Distillation to TVP/RVP
I am trying to do some preliminary work on a crude project, and have been warned that the particular crude has exhibited high vapor-pressure properties.
In the lab assays, I have alot of informtion, but no direct RVP or vapor pressure info. How do I convert to get TVP or RVP? Useing D86 Distillation data? Simulated distillation? Other data? Just looking for a quick range of VP, to see if I need to anticipate IFR, vapor recovery, etc.
RE: Convert Distillation to TVP/RVP
StoneCold
Vapor recovery for diesel isn't usually reqired, so for crude it's even more doubtful, however that may actually depend on the regulations applicable to the local area.
From "BigInch's Extremely simple theory of everything."
Are your tanks in an EPA controlled region?
