ASME Boiler Pressure Vessel Code
We need a waste heat recovery boiler to recover heat from a low pressure (less than 1 PSIG) syngas. The boiler is to produce 150 PSIG satuated steam. It is an unfired boiler. Does the boiler have to comply with ASME section 1 or ASME section 8? I have been told different things by different vendors.
RE: ASME Boiler Pressure Vessel Code
