searching text
3
searching text
searching text
Hello kind fellow engineers:
I would like my VBA code to return numeric value for a certain text ending.
For example
It should return 1 for finding .com
It should return 2 for finding .gov
However, the functions that I thought I could use IsLike and Like and Text Extract generate an error that says sub function not defined.
Any advice is much appreciated.
aja
RE: searching text
At a guess, I'd say that you've done something wrong in your code.
RE: searching text
For simple excel code, use:
CODE
=IF(RIGHT(A1,4)=".gov",1,IF(RIGHT(A1,4)=".com",2,"neither"))
For VBA, create a module, write this function
CODE
Function check_domain(ByVal domain As String)
domain = Right(domain, 4)
Select Case domain
    Case ".gov"
        check_domain = 1
    Case ".com"
        check_domain = 2
    Case Else
        check_domain = "neither"
End Select
End Function
RE: searching text
instr is better, since you don't have to fool with defining if you want to look at a certain number of characters on the left or the right side of the string; instr searches the entire string.
From "BigInch's Extremely simple theory of everything."
RE: searching text
I think this should do:
Sub test()
Dim Gov As Byte
Dim Com As Byte
    If Application.WorksheetFunction.CountIf(Cells, ".com") > 0 Then
        Com = 1
    Else
        Com = 0
    End If
    If Application.WorksheetFunction.CountIf(Cells, ".gov") > 0 Then
        Gov = 2
    Else
        Gov = 0
    End If
    MsgBox "Com = " & Com & ", Gov = " & Gov
End Sub
But if all you really want is to find out if the .com or .gov strings exist in the range or not, you might want to return a TRUE/FALSE instead of a numeric value.  If so, this might be better:
Sub test2()
Dim Gov As Boolean
Dim Com As Boolean
        Com = True
    Else
        Com = False
    End If
        Gov = True
    Else
        Gov = False
    End If
End Sub
The following will return a count of the number of times that the search terms are found:
Sub test3()
Dim Gov As Long
Dim Com As Long
    Com = Application.WorksheetFunction.CountIf(Cells, ".com")
    Gov = Application.WorksheetFunction.CountIf(Cells, ".gov")
End Sub
RE: searching text
My solutions above look in the entire worksheet for the search values.  If you want to look in only a portion, even a single cell, change the "cells" in the CountIf function to the limited range that you want to search, e.g. Range("A1") or Range ("A1:G50").
