Hoasote Firestall Roof Deck
Has anyone used this product as a structural diaphragm? The data available seems to be limited to two test results and does not contain the typical span/shear charts versus connection schedules that I am accustom to seeing. The architect is proposing to use this deck as a single element diaphragm, as opposed to using a structural steel deck under the nail-able deck. I'm being asked to render an opinion. Any thoughts/comments are greatly appreciated!
RE: Hoasote Firestall Roof Deck
The product may be acceptable for low shear values. The project in question is a 30,000 SF facility and I anticipate significant diaphragm shears.
Thanks!
If mfg can't back their product - whey do we (including architects)even consider using them??
I suspect price
