Inconsitent lightweight load behavior
Hello NXer's
As part of a battle an ongoing battle to improve the way/speed with which we open assemblies, I have been playing with assemblies using the light weight load option. Now I was lead to believe that unless we refiled our old NX 4 parts, then we would not get the option of using light weight reps, however after some pretty in depth testing, I'm seeing some quite erratic behaviour.
1. Open a large assembly with a mix of data from NX4 and stuff that has been created/modified in NX7.5 and there is a mix of lightweight and exact reps. However on further inspection, there are some parts that are part family members where some components open as exact and others as light weight, even though they have not been refiled or saved since 2008. right clicking on one that is shown as light weight and changing it to exact works, but then it will not allow me to change back to light weight, so it appears that the ANT is not displaying correctly.
2. I open an engine assembly and every part but 2 loads as light weight. I change my selection intent to facet body and try and select the whole assembly and only 50% (ish) selects leaving some very large components in view but still shown as being light weight in the ANT. right click and change these to exact and it opens the rest of the model and all the faceted edges disappear as expected and I can also change back to light weight. The thing I don't understand is why these bodies are not facet bodies and wont select when in light weight mode.
3. I open an assembly that has a large casting in which has not been modified since 2009 which will not have a lightweight rep, but for some reason I can can switch it between light weight and exact without any problem.
It seems as though the behaviour is very inconsistent. Has anyone else noticed the same?
Baffling me. :-?
Best regards
Simon NX7.5.4.4 MP5 - TC 8 www.jcb.com
RE: Inconsitent lightweight load behavior
In the case of NX 7.5 (or NX 8.0 if you're skipping NX 7.5) we highly recommend that you run refile on ALL your active files INCLUDING your Reuse Libraries (AKA Family Table members).  Now you can skip the Master Templates but the currently created family member parts should be refiled.
What I suspect is that some of your older legacy parts may never had proper lightweight (or what we called 'faceted' models back then) data generated in them and until they are saved, either manually after opening or via refile, they will continue to be a cause for some of the inconsistent behavior that you're seeing.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
Some companies are reluctant to refile - saying there are risks>
Any thoughts on this, John?
If anyone finds any problems with refile they should contact GTAC immediately since this is one of the most critical pieces of code we deliver with each release and is tested thoroughly.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Our problem is out multi site set up.
We have 10 sites around the world.
A part can only be owned on one site.
The part has to be refiled on the site where it is owned.
Many of our parts will be used all over the differnt sites which means there are many copies of the part.
These copies can not be refiled, which means lots of time filtering parts.
Therefore we have to identify where each part is owned and refile locally on that site.
All refiled parts will then sync overnight back to the central server where all released parts are copied to.
If the part/s have been imported for use on other sites, then once they have sync'd back to the central server, they will then also be re-exported to those sites.
This will mean masses of data being moved around on a night time.
we have around 750,000 parts to refile.
The logistics are just beyond comprehension.
Nobodies fault, nothing we can do, it's just the way it is, but it has meant that it will be a very long time before we can get full benefit from the light weight reps.
We can't even get each division to revise their parts as suppliers will use this as an opportunity to requote and raise their prices.
Dooooom!!!!
Best regards
The most critical parts that need to be refiled are the Reuse Libraries since they are considered as 'read only' by NX and therefore do not get updated automatically as files are opened and saved during the normal course of work.  Even legacy parts which are not saved duing a normal session shouldn't be an issue as long as there was some sort of lightweight (faceted) Reference Sets in those legacy files.  However, the family table MEMBERS must be either regenerated from scratch or refiled.  There is not other choice.  I you do not, you will have continuing problems getting correct drawing views whenever an assembly includes nay of these non-refiled Reuse Library parts created prior to NX 7.5.
John R. Baker, P.E.
Industry Sector
Cypress, CA
