very low CTE moldable plastic looking for lower melt temp suggestions
We currently are using a Sabic ULTEM 2410, 40% glass material for a project but would like to find something of a similar CTE but with a lower melting temperature. Ideally something with a similar water absorption (as this part is continuously submerged in fresh and salt water) and with similar flow characteristics.
Water Absorption 0.130 %
Melt Flow 5.20 g/10 min
CTE, linear, Parallel to Flow 14.4 µm/m-°C
Max operating temp of our product is 80C
Any ideas?
Any ideas?
RE: very low CTE moldable plastic looking for lower melt temp suggestions
Semi-crystalline polymers should have lower CTE than amorphous.
Water uptake depends on polarity so low polarity polymers like polyolefins and styrenics and good whereas nylons have high polarity and take up lots of water.
Based on what you've said I'd look into syndiotactic polystyrene. It has amazing flow and really low water uptake. Contact Tom Fiola at Idemitsu (the product is called Xarec).
Also search www.matweb.com for free to find materials with the CTE you want.
Chris DeArmitt - PhD FRSC CChem
Plastic & Additives Webinars
Instant Downloads & Inexpensive
www.plastictraining.com
Also, unless this is a student homework question, I suspect there are many other requirements that have not been mentioned as Ultem is an expensive high end product and many cheaper materials are good for low expansion and 80 deg C continuous use.
Without further information I would also look at polycarbonate and modified PPO and maybe even a high heat ABS.
MFI is not that good an indicator of maximum flow length. Flow length to wall thickness ratio data is much more useful.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
In order of mechanical importance;
Low CTE (variation in expansion / contraction is typically the highest failure mode in products like this one)
Lower molding temperature (this is causing manufacturing issues thus preventing the product from being made consistently)
Low water absorption (this is also a source of failure but much less than a high CTE variation
typically we've found that a well selected low CTE material will have good dimensional stability within our range so selecting a high glass material (or other filled plastics to limit dimensional changes with temperature) takes care of the dimensional stability side of the problem. Of course we need to bond with our substrate as well but that's a chemistry problem that we can take care of.
http://t
Melt temp maybe too high at 280C, but heat of fusion very low (hence very rapid cycling ability)
H
www.tynevalleyplastics.co.uk
Why be happy when you can be normal?
