NX2 - converting multiple sheets into a single sheet
I am running NX2 and need to convert multiple sheets into one single sheet that will behave as a single sheet after.
I tried sewing the sheets, but in CAM to create a tool path you can not select the SEW  as one single sheet.
Also I tried to subtract / intersect the sheets with a block.
The result remains the same, the solid / sheets do not behave as a single sheet.
Is there a soltuion to this ?
Sebastian
RE: NX2 - converting multiple sheets into a single sheet
Maybe try Insert>Combine<Join Face after ewing.  It works in 7.5,  it's been a while since I used NX2.  Menu structure/syntax may be different.
After "sewing", that is.
NX2 was way before my time, but if I was doing this now I'd go Edit > Feature > Remove Parameters to turn the original sheets and their sew operations into one resultant Body, is there an NX2 equivalent of this?
It will mean that you can't go back and edit the Sews, but as long as that's ok you should end up with a single sheet body.
HTH,
Jon
JHTH
NX 7.5.5 + TC 8.3.2.2
Unless something has dramatically changed with the CAM module since then there should be absolutely no problem with generating a tool path on a surface composed of multiple sheets. Exactly which type of path are you trying to create and why is it a problem to select both sheets?
Join face might work for you if the two sheets truly do form a continuous face with matching UV curves. I have found this to be by far the exception rather than the rule in my work but you might have better luck depending on the geometry.
If join face doesn't work, and you really do need one single sheet, you will need to extract UV curves from the existing sheets, chop them back a bit from the intersection, create bridge curves to span the intersection, and then create a new sheet from the modified curves. The number of curves you will need will depend on how complex the surface is and how closely you need to duplicate the original sheets.
Unless you are trying to do something that is pretty out of the ordinary, or are trying to develop some type of automation that depends on having a single sheet, I think the chances are about 99% that CAM will do everything you need without any further work on your sheets.
Hope that helps.
NX 7.5.4, NX 8.0.1.5
Tecnomatix Quality 8.0.1.3
PC-DMIS 2011 MR1
While "Remove Parameters" can be useful, it will not change anything about the sheet bodies themselves. What it will do is remove the reference to the original, individual sheets. Perhaps this is what you are seeing? When you have multiple sheets that have been sewn together you have several different ways that they can be selected. You can still select each sheet as an individual and you can also select the "Sew" feature as a single unit, which will select all sheets included in that sew operation.
Again, though, this is just selection intent stuff. It should have no effect at all on how the CAM module creates a path.
PC-DMIS 2011 MR1
Thanks for the quick responses !
Mmauldin: Unfortunately NX2 does not have the Join Face command after SEW in the SEW options.
Jon: I removed the parameters from the SEW, but when I select the sheet as a general object, it actually only selects each individual sheet....same behavior as before.
DaSalo: The surface is not really complex – it is a deck of a surfboard – and I am able to create a toolpath with the toll axis being Z.
But I need the tool axis to be Y as I want to cut the deck with a disc, instead of a bull nose cutter.
And I would like to use, FIXED CONTOUR with the Surface Area Drive method.
Here is where the actual problem starts, as I cannot select the sheets/surfaces for the drive geometry – I get the error message:
Cannot build Grid: Drive Geometry will be erased
Note: Grid may work if chaing tolerance is changed
Back out of edit and got to preferences – Selection.
Please see the uploaded pic to give you an idea of what I am looking for.
NX2 should have the "join face" command. I think it is under the "edit face" menu.
Hi Jerry,
I checked that thread prior to my post...unfortnatyl it does not solve the problem...
I found the join face command under edit face menue, but unfortunatly it results only in error messages....
The only function I think would do what you are looking for would be "quilt'. It is not intuitive and easy to do but it creates single face/sheet from multiple sheets.
NX3 + TC9
Wacio, yes ...I tried that also already, but could not get it to work...have been reading about it in the forum as well...is there a hint to get it working ?
Found this in another thread:
"NX-2 and NX-3 The Join Faces command works very well for a range of simple examples and can be found under Edit>Face>Join Face. It appears to require only one selection pick in most cases so I can see why it is favored." - Hudson888
Found it here: http://www.eng-tips.com/viewthread.cfm?qid=225552
Again, it's been a while since I have used NX2, so I'm not sure if this is applicable or not or whether it behaves as it does in NX7.5.
Hmm...I seem not to have too much luck here ...I can select my two rail sheets, but I cannot select the deck...here I get an error message:
Face is not parametrical- rectangular
I attach the file for reference...might be easier.
A few of the top surfaces would join in NX7.5.  The center surface joined using the "On Same Surface" option and the two outer worked using the "Convert to B-surface" option.  Nothing worked the bottom side.  It'll take someone with more surface experience than me to make that work.
Since it is symmetrical you may want to focus on sewing only half of it, then mirroring it. Sometimes you have better results that way.
Thanks mmauldin....
Jerry, well actuall the surfaces are mirrored...problem I guess is that you, can not sew into solid then...only if I create another surface to close that half...
Tried already just sewing one side and then tried all of the above...also not really with success.
I think you are looking at this backwards. You might want to spend some more time learning about the surface area operation and how it expects the surfaces to be selected. A much easier solution in this case is actually to create more surfaces, but in a regular, grided, pattern.
Surface area must have an evenly grided collection of surfaces or it will fail every time. You can't select 1 surface, then 3 in the next row, then 2 in the next row. You must have 2, then 2, then 2, then 2. Or something regular like that. I was able to generate all kinds of paths with your geometry by simply using projected curves and the "Divide Face" tool to slice your surfaces up into an even grid.
The tail and tip get difficult because you have 4 sided surfaces in the center converging into 3 sided at the tip, and into a kind of six sided at the tail. This is very difficult geometry for a CAM system to deal with and is definitely something to stay away from when creating your model if there is any way around it. Try to keep your surfaces regular. That will get you much further than just trying to create fewer of them.
The best tool for your particular model if you want to do the least amount of manipulation is "Streamline". You don't have this in NX2 and if you are doing this kind of work as a serious business it will pay off for you to pony up the money and upgrade to NX8.
Attached are a couple of images of paths created with Streamline. The only modifications to your model are the addition of a couple face divisions near the tail so I could better isolate that geometry. Less than 5 operations in the feature tree and less than 5 minutes of time in modeling.
Hope that helps.
PC-DMIS 2011 MR1
Final comment: It looks from your JPEG that you have a CAM package that is designed specifically for this application (surfboards). Why not use that? NX can definitly do everything that any other CAM package can but you might have to do some significant customization to get it to behave exactly like a package that is tailor-made for you specific application.
PC-DMIS 2011 MR1
Hi DaSalo,
Thanks for the big support here.
I agree that it would be easier to solve it in the CAM. But I could not get it, so I was looking for a different solution.
The JPEG was actually just to show what I want to achieve, I am not using that software - it can not manage any import. I use only the CAM of the NX2.
The toolpath that you got looks like what I want.
I tried to split / divide the surfcace like in your pic (also with more divisions), but I am still getting the same error message on the surface area/drive geometry.
Uprading to NX8 could be an option, but I am a one man show here and that is quite a big investment. If I can find a work around in NX2 it would be better.
I don't have NX2 so am not going to be able to help you out in any more detail with exactly how to get it to work in that version. My recommendation is to spend some time generating paths with Surface Area using a simplified shape. Remember that Surface Area is looking for even bands of surfaces. Each band (the software calls them "rows") must have the same number of surfaces as every other band. You choose the surfaces in the first row in sequential order, lets say from right to left. Then you click the button that says "select next row". Then you pick the surfaces in the next row in exactly the same order as you picked the surfaces in the first row. Once you have selected the first two rows the software will understand which direction the selection progression is moving in and you do not need to hit the "select next row" button anymore. You do need to continue to choose the surfaces in the same sequential order, one row after another, until you get to the end of the part. This regimented surface selection is absolutely essential for the tool to work correctly.
99% of problems with Surface Area method are due to incorrect sequencing of surface selection. Occasionally you do need to open up the chaining tolerances if you have small gaps between sheets or your surfaces are almost regular, but not quite. You do this in Preferences => Selection. In NX7/8 the setting as at the bottom of the dialogue window and will have a method, which I set to "Simple", and a tolerance, which I set to ~ 1 to 5x my modeling tolerance. On very rare occasions you might need to bump that tolerance up even more. Sometimes it actually works better if you set the tolerance tighter so don't just put something huge in there in an attempt to eliminate the influence of that setting.
Once you have a solid understanding of how "Surface Area" works you will be able to clearly see how the patch layout in your model will fit into this selection scheme. You will notice some very obvious problems with the surface layout. With this foresight about what is required for manufacturing you will be able to go back and rework your surfaces appropriately.
Another thing you could try is building a new surface that is appropriately grided that can be defined as the drive surface. The drive geometry does not have to be the surface of your part. You can have some other surface with a similar, but simpler, shape that mimics the flow of the part. The tool path is generated by tracing the drive surface and then projecting onto the part surface along the defined projection vector (usually use "Normal to Drive" for something like this, but others will work). If you have a "Cut Area" selected that will also be considered. Using a separate drive surface like this is more time consuming, because you need to model it, but allows you to cut virtually anything regardless of how the original surfaces are structured.
Streamline essentially creates this extra drive surface for you in a very automated way and works pretty darn well for stuff like this.
PC-DMIS 2011 MR1
Dear DaSalo,
Thanks for that explanation! I think this is the way to go!
I managed already to get the desired toolpath for the center of the board -I am only missing the tail and nose- by breacking up the surface into an even grid -   But I feel I am very close now.
Thank you so much and I will let you know once I have it completly worked out.
Like you say, it comes down to the grid and selection. Same in NX2.
Hi DaSalo,
as always, once you have one problem solved, the next on comes up straight away...
I got the toolpath going 95% now, but the problem is, that once the disc passes the wide point of the board it keeps cutting with the front and the back actually goes to deep in  the board...
I uploaded a screenshot for better understanding.
Is there a way to prevent that ?
Problem solved ! Choosing the tool to be a T-cutter made it work...
It won't gouge if you select the entire surface of the board as your "Part" geometry. Then you set the tolerances in Cutting Parameters => Stock. There is also a box in the "Surface Area" dialogue that allows you to choose the behavior when gouging. Set it to "Warning" or "Retract". This will significantly increase the amount of time it takes for path generation so be prepared. You are working with a bit of an odd tool so will need to get creative to get this to work out as you hope. I'm sure it is possible but you might need to play with it for a bit to figure out the different a settings.
Why can't you just finish one side down to the mold line with a ball endmill, flip it into a nest, and then finish the other side down to the mold line?
Get yourself a good vaccuum table, mill a nest from some stacked up MDF, put in a few locating stops if necessary, and your good to go.
PC-DMIS 2011 MR1
Using the T-cutter actually seems to work very easy.
Please see attached screenshot.
The problem with the machining is that these are standard machines to cut surfboards...and I can not midify the settings, as it is not my machine.
My own machine has a ball end mill and we have no problem. But I am in Portugal and the board needs to be cut in Australia.
Anyway, all good now...just need to work ou the last details in nose and tail and I am good.
Thanks again for the amazing help here !
Cool, glad you got it working! Once you get the hang of "Surface Area" the sky's the limit. You can cut anything with that method if you take the time to set it up correctly and you understand exactly what information the software needs.
Can you post a photo of a finished board?
PC-DMIS 2011 MR1
Oh, one thing I will add. If you haven't discovered it already you might want to look into the option in the Surface Area dialogue that allows to you define the percentages of the drive surface that you want to use. I'm at home now and can't remember exactly what the option is called. There is a way to either truncate or extend, both along and across the cut direction, the drive geometry. This might help you to get out to your nose and tail. This is how I got the path to cut the tail nicely in the images that I sent. I only specifically defined a drive surface up to the point where I added in those extra face divisions near the tail and then set the percentage of the drive surface to 110% in that direction. This effectively extends the drive surface. As long as the part does not change shape radically in this extension area you will generally still get a very good, clean path. You can also use a negative percentage to extend from the opposite end. Hopefully this option is available in NX2, it is very useful for fine tuning the path and for blending one operation into another.
When you get some spare time I would still look into creating a completely separate drive surface. I think that will ultimately be the way to go so you can be totally free with your design and still have confidence that you will be able to quickly generate the toolpath. If you get a good, generic drive surface worked out, maybe something that will scale parametrically with your part through expressions, you will likely be able to create a nice template that will allow you to cut any board that doesn't radically deviate from this shape without any modifications to your CAM operations at all. Then you can just design all day and kick out the toolpaths as an afterthought. This is where NX really gets cool and everything else gets left in the dust.
PC-DMIS 2011 MR1
Hi DaSalo,
a BIG Thank you for all your help! I would not have made it without your support. We have cut the first board today and the result is great.
I attach you a first picture. The shape is actually a little different to what I have uploaded before. It's a 12'6'' Stand Up Paddle board...
Congratulations! I'm very glad that worked out for you. Thanks for uploading the pic.
Any tips that you can share about how you were able to refine the path to get exactly what you needed?
PC-DMIS 2011 MR1
Hi DaSalo,
just coming back to how I did it.
I actually followed your advice and designed the surfaces / grid in way that it was selectable.
So the drive geometry and the surfaceds to be cut were the same.
But I also understood how I could use this new geometry to cut a surface that maybe not identical to the drive geometry.
Again a big thank you, we have been cutting more boards already in Australia and it just works perfect.
Hi all, i am Surfboards Shaper, and i would like to know if the NX8 it works fine to generate the tool paths for the surfboards, im traiyng work with this software but i never get the toolpaths, Someone know how its do?
i work with the shape 3d or board cad to draw the surfboard, because its mor simple and fast, i export this shape with step extension , i import to the NX8 and now someone can help me how can i do the rest?
Best regards
