problem with MAP SOLUTION
Hi all, I' trying to apply the MAP SOLUTION but I receive always this message:
***WARNING COULDN'T FIND A CORRESPONDING REGION IN THE PRIOR MODEL FOR PART INSTANCE PART-1-1, ELEMENT 12, MATERIAL POINT 1. ALL SOLUTION QUANTITIES ARE SET TO ZERO.
What should I do?
What should I do?
