Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...it was ingeniously designed and all those clicks were for my own good... and that was even before I got my speedy and useful answer to my tekkie question that I eventually posted..."
Geography
mtbnski7 (Mechanical)
26 Feb 12 0:07
I have a pinion exposed to 100 oz-in torque and a gear exposed to 300 oz-in of torque (gear ratio of 3).
Does the pinion need to have a torque rating above 100 or 300 oz-in?
dinjin (Mechanical)
27 Feb 12 22:15
Torque is simply a force times the radius.  The force is to be equal in both and the torque is simply dependent on the radius.
If the radius of the gear were 6 times the radius of the pinion, the torque of the gear would be 6 times the torque of the pinion.
Always look at the force on the tooth and not the torque.  Torque confuses a lot of folks.
tbuelna (Aerospace)
27 Feb 12 23:23
mtbnski7,
As dinjin notes, the tangential pitch line force is the same for both gear & pinion.  However, that does not necessarily mean the teeth on both gear & pinion are equally stressed. The bending strength will typically be higher for the gear teeth than for the pinion teeth.  If the mesh contact ratio is low, it is helpful to use profile shift to help equalize the tooth bending strengths between the pinion & gear.
Hope that helps.
Terry
leisure17 (Mechanical)
28 Feb 12 7:45
I think you answered your own question. If the pinion is exposed to 100 then that's what it should be rated at. The confusion seems to be the rating of the gearset/gearbox. when you stipulate a torque then, you must say where it is. eg, 300 oz-in output torque, and then if you know the ratio it's a simple matter of calculating the rest
28 Feb 12 14:24
Thanks, that's what I thought, I just wanted to make sure I was thinking about it right.
Close Box
Join Eng-Tips® Today!
Join Us             Close
