Fully Constraining sketches in NX
I saw this post thread561-216355: Need to fully constrain sketches and heres my two cents about why I thought fully constraining a sketch was so important.
A unconstrained sketch is one which does not have a single solution for the given constraints/dimensions i.e a different shape could be expressed using the same set of constraints.
An example: rectangle with only one side dimensioned would mean that its other side could have any length (let alone the position of this rectangle in 2D sketching space or the angles of its sides). So you could never be sure what the exact shape is especially after moving/tweaking it around in the sketcher.
More so with the case of more complex shapes -> You make a rough sketch keep adding dimensions and you think you have enough but say a line you assumed is perpendicular is actually at angle of 89.9deg. you couldn't be sure unless you explicitly added a constraint/dimension for it. Also you couldn't be sure there weren't any other such errors if the sketch wasn't fully constraint because for that set of constraints you don't have one single geometry as a solution.
So now when your CAD modeling goes for machining. The CNC machine code is generated based on the solid model (the same one with that side off by 0.1 degs) and comes out with the same error.
No wonder companies make it policy to fully constrain sketches. And using Fixed / Constant length / Constant Angle constraints is like shooting your self in the head. Lets say you put a constant angle constraint on that line which was at 89.9degs just so you could satisfy your companies policy and produce a fully constraint sketch - well now your sketch even hides that there and error in there!
-Vik
-Vik
RE: Fully Constraining sketches in NX
NX 7.5.4, NX 8.0.1.5
Tecnomatix Quality 8.0.1.3
PC-DMIS 2011 MR1
