Controlled lubrication to atomize or not to atomize?
Hey guys I am working on a auto lube spray system for a pipe bender. I need a very controlled spray like that of a one sec squirt of a can of spray paint with a flat spray pattern with a 45-90 degree angle on the width. This is because in order for the nozzle to be out of the way of moving parts but, close enough to not make a mess, the nozzle must be about 6" above the part to be lubricated.
The part to be lubricated is a 1" diameter by 6" long mandrel rod that acts as a guide for the copper tubing as it slides inside the tubing while bending. The hardest part to this project is finding the correct spray nozzle to work within this specific pattern and is not huge and cumbersome.
So my question to you math geniuses out there, is if there is a formula to figure the correct cfm needed for this coverage or if you know the cfm of what a can of flat patterned spray paint is?I can control the cfm via the PSI I assume but the other question is if I should go with a atomizing system which mixes air and the oil(which is a very low viscosity oil called OAK oil) or to just go with a system that pushes only oil through the nozzle via air pressure in the oil supply tank?
Atomizing systems,at least the one we have here, seem a little harder to control a specific pattern,oil volume and are overall more messy. But the ones we have are not a specific pattern. They are just the generic nozzles on the TRICO Spray Master system like this one.
h ttp://www. ebay.com/i tm/Trico-3 0458-Spray master-II- Spray-Cool ant-System -/13062562 7402?pt=LH _DefaultDo main_0& ;hash=item 1e69e4e50a
I know it seems like a easy thing made complicated but I have attempted to contact several nozzle manufacturers and none of which can seem to tell me if I will be able to control it as I described above. Control is critical because if it makes a big mess than this project will be a flop and I have convinced my boss to spend money on a system that will be impractical.
Thankx.
The last question is
h
Thankx.
RE: Controlled lubrication to atomize or not to atomize?
Atomized oil is a fire hazard.
That's not the worst of your problems.
It's also a breathing hazard.
It works something wonderful for cooling cutting tools, but OSHA pretty much shut down the technology years ago.
Mike Halloran
Pembroke Pines, FL, USA
Anyways back on topic. So an unenclosed atomized system is no good got it. But I can still do this with a non atomized spray nozzle right?
If I get another job, I'm between jobs. If not, I'm retired.
Don't take my word for anything.
Do read up on spray systems and OSHA.
Notice particularly the huge variety of water based coolants offered for sale.
Mike Halloran
Is the liquid delivery method in spray paint and windex both considered atomizing? Does it combine air/liquid or just use air pressure to push the liquid through the nozzle?
Finally,Does anyone know of any nozzles which has 2-3 stream tips that would be the size of a 1/8 npt fitting and spray 2-3 streams of Oak Oil(viscosity of water and evaporates) in a /|\ or /\ pattern?
I cannot seem to find a specification or a supplier.
I searched for "mandrel lubrication" with and without the quotes and got a number of products other than Oak Oil, and quite a few application systems that claim to just bolt onto your bender.
Check that you're not reinventing a wheel.
Don't quote _me_, but I think that regulatory authorities don't make a particular distinction about whether compressed air or compressed gas is involved in atomizing liquids, but they do care about the droplet size.
Have you tried foaming the Oak Oil? I have no idea what OSHA might say about it, but I've had good results foaming Marvel Mystery Oil using a Dial (hand) Soap Foam dispenser. (Buy two; use the soap in the first one, then refill it from the second. What remains is a air/liquid pump that hasn't ever had soap in anything but the dip tube.)
Mike Halloran
I guess Oak Oil in a nickname because they use it on Burroak tooling alot.
But if you could post the link of the bolt on system you would be my hero. I tried to find one. The problem is it has to be smart enough to know when to spray. That means automation of some sort. But if there is a sytem that can simplify even part of it I am more than greatfull to know about it.
"mandrel lubrication" "<your bender's make and model>"
Mike Halloran
So I have to go with a spray system but I am looking into a tip that would spray 2-3 seperate stream so we dont get into oil mist situation.
Mike Halloran
#301 is sprays the stream I need but its 1/8 npt I need something the size of an air brush tip.
Any ideas? I wonder if its possible to get a stream with a air brush tip?
A problem I saw was he nozzle continued to leak after there was no pressure. This would be a problem if the nozzle leaked in between sprays because it would make a mess as the nozzle will be facing down.
But my question for you guys is:
What can I do to prevent this? Or is this even an issue once the valve is on the liquid side? Im thinking like when you hold your finger on a liquid filled strawl in the vertical position,how no liquid will escape.
Mike Halloran
What would be wrong with a positive displacement pump pushing the oil through a properly sized spray tip??
Do you need the air for some reason??
Go talk to an old, balding commercial paint equipment guy.
