[motion] friction between objects
Is it possible to create some sort of friction of damping between plannar objects? The whole mechanism works fine except for one part that is pushed forward over a flat surface. The path of the part is not exactly defined, only begin and end point are known. Sometimes it moves close to what one would expect, but most of the time it bounces back and forth with every push (like it is moving on ice). I don't have much experience with motion, but linkages and all that work fine.
RE: [motion] friction between objects
