Can someone help me with this syntax error?
xi = zeros(1024*655,2)
counter= 1
for y = 1:1:655
    for x = 1:1:1024
        xi[counter,1] = x
        xi[counter,2] = y
        counter= counter+1
    end
end
There two syntax are indicated as an error in matlab : xi[counter,1] = x; xi[counter,2] = y
Can someone please help me correct this syntax? I am trying to recalculate at different points.
Thank you
RE: Can someone help me with this syntax error?
Try using round brackets instead of square brackets:
CODE
xi = zeros(1024*655,2);
counter= 1
for y = 1:1:655
    for x = 1:1:1024
        xi(counter,1) = x;
        xi(counter,2) = y;
        counter= counter+1;
    end
end
(2B)+(2B)'  ?
Square brackets [] indicates a C (or C++) programmer. Beware also that Matlab arrays aren't zero-based. A very common issue for code conversion.
- Steve
