Box selecting multiple faces
I'm trying to quickly select a bunch of faces, it concerns a standard part downloaded from the net that has too many little notches and details and I want to use remove face to get rid of them.
Problem is, selecting faces one by one is tedious. I can find no way to box select a whole bunch of faces. Not with the selection traps, nor with the selection filters.
There must be a way!
Certified SolidWorks Professional
RE: Box selecting multiple faces
Fernando
Win XP64
R20/21, 3DVIA Composer 2012, ST R20
Dell T7400 16GB Ram
Quadro FX 4800 - 1.5GB
But you can try to use different ways to select topology of the elements (in other words, use Look: Visible on screen (is just an example) or some other criteria.
See picture attached.
Fernando
