Raft or a strip
Raft or a strip
Raft or a strip
Hello.
Guys can you plase help me a bit.
Wich one of these solution can be classifed as a raft foundation and wich as a strip. Foundations are located under masonry /concrete walls.
You can see reinforcement in the pictures. Some part are reinforced and some non.
The minimum foundation depth is 80cm because of the frost.
Can you maybe recomend some other solution.
Thanx
