Laboratory Instruments Maintenance Support
For Following Laboratory Instruments which are 12 years old are presently offline due to reasons shows against them :
1. Hydrogen Generator – SOV and Pressure Transducers spares not available.
2. ICP – OES - RF Generator is not available with the OEM.
3. TGA – Thermo gravimetric analyzer – Rotor is not working and in-built balance calibration frequently goes out .
How can we make these instruments operative with spares support from similar application ?
RE: Laboratory Instruments Maintenance Support
Pull the pressure transmitter and it out for manufacturer ID. Contact the manufacturer to decode the model # for a range, output type, operating voltage, mounting whatever and find a substitute.
