Pedestal-Supported Concrete Slab Analysis
Does anyone know of a method of determining the flexural capacity of a concrete slab supported by pedestals, subject to a point load? Such as in a floating concrete panel patio deck?
Think of a concrete slab section (say 24" x 16") simply-supported at each corner by pedestals (pedestals are not fastened to the slab, nor are they part of it, the slab just sits on them).
I would like to analyze this slab with a point load in the centre, or a load distributed over 1 sq.ft. in the centre.
I've searched through publications, textbooks, and Google to try and find an analysis method, but have so far come up empty-handed.
Any help at all would be greatly appreciated.
Matt
Matt
RE: Pedestal-Supported Concrete Slab Analysis
Or is the plan of the slab 24 ft. x 16 ft?
I'm confused.
The slab is like a sidewalk slab (24" x 16", or any other size).
It sounds like Yield Line theory would be the way to do this by hand...I've seen this mentioned on here a few times before and have done some reading on it recently...there are a lot of publications out of Denmark on the subject. Just google 'yeild line theory' and you'll probably have more to read than you were hoping for.
Depending on the span and thickness of the panels, they will likely be governed by shear, rather than moment or deflection.
With a few checks you might find that applying the maximum load near one of the 4 supports results in the worst case shear effect. The potential failure surface should be pretty easy to find given the size and shape of the pedestals. You will need to decide whether the cracked or uncracked section is appropriate.
There may also be precast manufacturers who will provide the panels based on specified load and support condition.
