compressed air pipe
compressed air pipe
Hello, guys,
Can anybody recommend a material for compressed air pipe in a lab? Let's say the pressure is around 10 bar (not very high).
Thanks!
Thanks!
RE: compressed air pipe
http://www
No tools needed to assemble, easy to modify/change, and very safe. Just mount the main line with enough clips to the wall to keep it safe from mechanical damage.
You can do the main runs in galv, black steel will corrode unless you have good drying. Filter at the terminations, particularly with galv as it flakes into the airstream.
Mike Halloran
Pembroke Pines, FL, USA
