Stainless Steel Properties at Elevated Temperatures
Hello all,
My work involves some stress analyses at high temperatures. I typically work with stainless steel weldments, but I am having trouble finding reliable yield strength values at these extreme temperatures (up to 1800°F) for evaluation of the designs. Can anyone suggest a code or other reliable source where I can determine allowable stresses for stainless steels at elevated temperatures?
Thank you for your help.
- T
- T
RE: Stainless Steel Properties at Elevated Temperatures
Plymouth Tube
I'm looking into the BPVC, Section II, Part D. However, those codes do not come cheap. For just Part D of Section II of the code it costs $690!!
304 RT 97/59 1600F 17/16 1800F 10/9
304L no data, it will be weaker
309 RT 90/42 1600F 21/18 1800F 11/na
310 RT 91/42 1600F 27/16 1800F 13/na
316 data only goes to 1600F 24/16
410 strength will depend greatly on C content
high C 1600F 14/9
low C 1600F 11/7
Plymouth Tube
This take careful design work to avoid unpleasant and very expensive results.
Plymouth Tube
There are some useful data in Boller-Seeger and Baumel-Seeger series of books "Materials data for cyclic loading".
As a part of my academic effort (I work on methods for estimation of cyclic and fatigue material properties) I have put together database of referenced material datasets.
Authors allowed me to include data from these books in it.
I don't want this to be considered advertising, so contact me directly, if you need access to these data.
Best regards,
Assist. Prof. Basan Robert, D. Sc.
- API 530
- Steel Castings Handbook, Supplement 9, Steel Founders' Society of America
- Supplier's datasheets [Probably your client's approval is required for use of the data.]
Thomas Eun
