Two Phase Under Voltage Relay
   Can anyone suggest Two Phase Under Voltage relay? I am looking for a auxilary relay which can be mounted on DIN Rail  and I have only Two Phase(R and Y) of VT as input.
Thanking you in advance.
Yeruk
RE: Two Phase Under Voltage Relay
If all you have is R and Y, use a single phase relay. If you have a third wire, how is it derived?
Bill
"Why not the best?"
Jimmy Carter
What Bill said.
You can two single phase relays and connect contacts of them in parallel or in series
Can you use a 3 phase relay and wire 2 of the relay inputs with R and 1 input with Y?
IS this really 2 phase (vs. open delta)?  If so, I believe you can look into protection and controls for German based railway systems, which are 2 phase.  Siemens, Alstom, ABB, etc.
What is your exact application?
Three phase voltage rely can see not connected phase as loss of phase situation
Not if you connect one of the phases twice..
