Pressurized Vessel with PH Sensor and Level Indicator
I have been researching ph sensors and level indicators for one of my current projects. The problem I am running in to is that I can not find a sensor or indicator that can operate under the design temperature of the vessel.
The vessel is to be pressurized at 100psig @ 305°F and all wet material is to be teflon coated.
If anyone could even just give me some direction as to a company that has the products that can operate under these conditions it would be greatly appreciated.
Thanks in advance to anyone who can help.
RE: Pressurized Vessel with PH Sensor and Level Indicator
Take a look at Advantage Controls. They have a full line of automated blowdown & Blowoff systems including water chemistry sensors and samplers.
http://www.advantagecontrols.com/
Scott13
First off, awesome first name Scott.
Secondly, thanks for the links they were extremely helpful.
Just as a reference for you guys I happened to find this company that specializes in high temperature, high pressure probes, sensors, regulators etc.
http://www.corrinstruments.com/High_T_High_P_Probes/H_T_H_P_probes.html
Cheers,
Scott
