Minimum size for light gage stud wall
I have a single story structure with light gage roof trusses on light gage walls (2 exterior walls, 1 intermediate interior). Is there a minimum recommended stud size I should be starting my analysis from? In the past I have used 6" as a standard but I am wondering if I can use 3 5/8" or 4" for the interior load bearing wall.
RE: Minimum size for light gage stud wall
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
Download a free copy at:
http://www.rsgsoftware.com/
Mike, I actually left a message with one mnfr. But I think that 4" is the minimum I would want to use because so as to get provide adequate bearing for the truss above.
However, another free software that I have used is called Steel Smart System. It's put out by The Steel Network, and seems to be a pretty good software system. It takes some time to get it installed (they make you jump through some hoops) but it seems pretty good.
Will there be one continuous truss or two single span trusses? If two trusses, then do they have to align?
