Cast iron phase transformation
We have a cast iron fan hub which is stuck/corroded onto a alloy steel shaft. I would like to apply heat to the hub in order remove it from the shaft. I am aware of the the effect of heat on Q+T alloy steel but how will heat from an oxy torch affect the microstructure and physical properties of the cast iron? ie. will it be detrimental to future service.
RE: Cast iron phase transformation
Good Luck
