unpredictable sheet metal bend allowance
I found the sheetmetal bend allowance, which was defaulting to "K=0.5" has changed on a whole truck of my parts to "bend deduction=0"
I beleive this happened after I upgraded from 2010 to 2011 SP5.
My VAR doesn't seem to be able to tell me where this default is set, suggesting it is hard coded - SURELY they didn't change the hard coded default, particularly to bend deduction=0 which no material or tooling can actually create!
I use one template file which becomes a sheet metal file when I create sheet metal so the template doesn't currently have sheet any sheert metal parameters set in it - as far as I know.
I didn't do any setting files of my own because default settings were working just fine. Maybe I need to setup a bend table/bend note/guage toable files or something?
Can anyone explain this to me?
Currently I have someone looking through all the our sheet metal parts identifing which ones have "impossible" flat patterns.
RE: unpredictable sheet metal bend allowance
Jeff Mirisola
Director of Engineering
M9 Defense
My Blog
Diego
