Pipeline inspection
Pipeline inspection
We want to use CCTV technology to carry out a pipeline inspection, and condition assessment of some aged Cast Iron or/and steel pipes buried under a building. I am interested in knowing the limitations (Eg. minimum diameter of the pipe that can be inspected, bend angle, .....) of using CCTV for this type of work.
Thanks in advance
Thanks in advance
RE: Pipeline inspection
Sorry, couldn't resist.
- Steve Perry
http://www.linkedin.com/in/stevenhperry
This post is designed to provide accurate and authoritative information in regard to the subject matter covered. It is offered with the understanding that the author is not engaged in rendering engineering or other professional service. If you need help, get help, and PAY FOR IT.
the next tradeshow is in Nashville in mid March. Google 'Nodig'.
Richard A. Cornelius, P.E.
WWW.amlinereast.com
