Strip foundation variation
Hi guys!
Please look at the picture. Strip footing.
h ttp://imag eshack.us/ photo/my-i mages/836/ footn.jpg/
Is it safe to assume that all 3 footings will generate the same pressure on soil when loaded with force of same intensity?
If pressure is p=N/A, form here p=N/(0,6x1,0) for every solution.
Only difference that I see here it that 2 right footings must be analyzed for the moment that will appear on the 0,15m lenght.
And because of the smaller height, footing on the right will probably need more reinforcement.
Granular soil is assumed under the footing hence the distubution with bigger pressure concentration in middle part.
h
RE: Strip foundation variation
Only difference will be in the reinforcement beacuse of the 0,15m lenght offset.
