Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...One of the best run forums I have used in years! ...I like the way the site is organized and your no tolerance of flames..."
Geography
hello12345hello (Structural)
21 Feb 12 22:26
i have steel cantilever beam with simply supported beam back up. Column is continuous. i will have moment connection at one end as shown. if i will get upward load at the other end then how to design that connection. To design beam i will consider appropriate unbraced length.
jdgengineer (Structural)
21 Feb 12 23:27
Not to be rude, but you have posted a lot of fairly basic questions in the last little bit which may be better answered in your design office. Do you have someone in your office who can mentor you on your projects? Again I'm not trying to be rude but this forum is only good for so much and it seems like you could benefit from some more help from someone who can walk you through the design.
StrPE (Structural)
22 Feb 12 8:40
Yep, pretty basic.  An upwards shear connection is designed the same way as a downward shear connection.
Close Box
Join Eng-Tips® Today!
Join Us             Close
