Technical Translator
Hi Everyone,
Anyone know of a good technical translator online, hard copy, etc from english to spanish and vice versa? Neeed to translate documents for ce services in spanish. Thank you.
RE: Technical Translator
They are usually not that good....  Look at the Chinese instruction manuals you get when you buy a TV or a tool.
Hire somebody that knows what they are doing!!
@Mike: You have a point there.
Everyone else: Any suggestions outer?...I know we have intenational users on this site. Thanks in advance.
best to hire a bi-lingual engineer to do it.
What Spanish speaking country are you interested in?  Dilects can vary widely, so it can be advantagous to go local.
From "BigInch's Extremely simple theory of everything."
@ Biginch: No country in particular...My first language is actually spanish, orinally from Guatemala.  You can say that I speak 2 versions of spanish. One that is local and the second that is more mainstream and actually would be used for business. Therefore technical terminology would not change much from country to country (latin american that is). The original post was asking to see if there is something online that I can refer too or that I can providean empoyee as reference. By the way, the CE services would be here in the U.S. but at some point in the future would shift to latin america.
I've found that there arn't many engineers in the translation business.  You pay your money and edit a lot.  I've also found that there is considerable variation between all Colombia, Mexico, Venezuela, Argentina and Spain.  Un ejemplo muy comun, el "Concreto" de colombia y venezuela solamente les reconocen como "Hormigon" en españa, y no les gustan si alguien se le llamara diferente.  Les pintan como "suramericano" .. mi entiendes?
@BigInch - Te entiendo...completamente.
Thank you everyone for your input.
CPENG -
After 41 countries and trying to write technical articles for a wide range of readers (engineers, contractors, investors and local code administrators), I found that the internet is not the best route to go. I have tried translation programs (not specific enough), and found that an emails attachment to a local person is the easiest and most time-efficient, although the north to south difference is only an hour or two difference.
If the person on the other end is really good and proficient, the time and hassle is eliminated using a good cell phone plan for corrections and definitions is very worthwhile. - You need a person on the ground that you can communicate with.
I was involved is the sales,construction and starting up of a number of $5,000,000 concrete block plants in Russia and quickly rushed to the computer for an answer and all I got was a "concrete block plant" was a "beton black flower", which showed me that I needed immediate direct contact instead of a canned program or site and real multilingual professionals are not easy to find.
Just don't try to find a Spanish oriented translator for something in Brazil/Brasil, but cause they are generally Portuguese and are not always accurate between English/British and their native tongue.
International work is a very education experience on both sides.
Dick
Engineer and international traveler interested in construction techniques, problems and proper design.
