Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Where have you been all my life! I found the answer I needed in seconds..."
Geography
Irwin (Mechanical)
21 Feb 12 13:24
How could I generate a material wich is temperature dependent.
I have tried on several tests the temperature dependent material, but it seems it is not working correctly. Could anybody send me a NEU file which is correct?
BR,
Irwin
Helpful Member!  BlasMolero (Mechanical)
8 Mar 12 6:03
Dear Irwin,
Simply you need to know in advance the dependency of "each" mnaterial property with temperature (say EX, NUXY, etc..), this is the complex task, if you know this data you can choose to define the full value in the function curve or use the function curve as a multiplier of the nominal value of property.
You mentioned the format *.NEU, then I understand you are using FEMAP & NX NASTRAN: in this case, if you define the full relation between EX vs. Temperature using a function you can enter this function diectly in the field of YOUNG MODULES using Ctr-F and selecting the proper function in the pop-up window.
Alternatively, you can select the function in the tab FUNCTION REFERENCES
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB: http://www.iberisa.com
Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/
Back To Forum
Close Box
Join Eng-Tips® Today!
Join Us             Close
