Compressor running at maximum turbine power?
Hello all,
What does a compressor is operating at the maximum turbine power mean? Does that mean that it will be limited to a certain power and for an increase in delta P, the inlet flow will be less? For example, if it has to compress from P1= 78 psig to P2=400 psig with the maximum power, it will suck a certain amount Q1, if P1 increased to 88 psig with the same P2, then the compressor will be able to suck a greater flow Q2 with the same maximum power. IS this right?
RE: Compressor running at maximum turbine power?
I see that you have posted this question in another forum. Cross-posting causes confusion. Please read the forum policies, especially number 4 (the link is below my signature).
Suggest that you red-flag this post, or else post a link to your other thread here so that forum members are directed there.
Good on ya,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
