Modification of tank bottom design API 650
Is it allowed to modify by making a small pond on the floor of the API 650 tank design? Small pond that we need in order to suction pump to suck all the liquid in the tank and leaving little fluid on the part of the pond? If allowed, how safe way to modify it so as not to damage the structure of the tank? thank you
RE: Modification of tank bottom design API 650
