RA in Ovako 146s
RA in Ovako 146s
Hi All,
I have attached a micrograph of Ovako 146s case hardened steel, I am estimating around 10% RA in the case (independent lab from H/T company state "No RA") I am also achieving hardness results to support the level of RA agains independent lab results of >800Hv! Is there a more accurate way of determining without the use of XRD etc?
RE: RA in Ovako 146s
The above link is of the samples from the HT comapany and from an independent lab (supposedly from the same sacrificial test piece). Microstructures look very different and a difference in hardness of approx 200Hv.
Color tint-etching for multiphase steels
http://ww
Imaging of Phases in Steels
http:
Martensite and Retained Austenite
http://ww
Etching Techniques for the Microstructural Characterization of Complex Phase Steels by Light Microscopy
ht
