Question on use of affect/effect affecting/effecting
Hi, I am really having trouble having certainty, if using "affecting" vs. "effecting" is right...
The can wrapper may be removed without affecting the integrity of the container.
...and also use of "effect" vs. "affect" here :)
Procedures must never come into effect, which may confuse employees doing their jobs.
RE: Question on use of affect/effect affecting/effecting
That being said, personally I think I would accept either word in the first case but that 'affect' just sounds odd or clumsy in the second one, so much so that I would have to stick with 'effect' simply because it rolls off the tongue better.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
John R. Baker, P.E.
Industry Sector
Cypress, CA
effecting means causing or enabling.
affecting means changing.
- Steve
When affect is used as a noun, it's a mental state or psychological term (nearly always).
When effect is used as a verb, it's "to accomplish...," or similar.
The police officer effected entry into the house with his battering ram when he observed the old gentleman lying on the floor.
When the police officer struck the door with his ram, the effect on the old man's nap was immediate.
The sound of the ram striking the door affected the old man's slumber; he snapped awake and sat up straight.
Sorry for the disjointed treatise. My lack of coffee this morning has affected my thought process. The effect is rather profound. I think I shall go upstairs right smartly for another cup.
Good on ya,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
So, assuming by the responses... the sentences I wrote use the word right/ok? :) Seems to be a bit of grey area in the use of the word on topic sometimes...
No, you used them correctly.
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
If I can't remember which of the common usages is which, I recall that the analysis is called a FMECA, not a FMACA - amd is analysing consequences rather than actions.
A.
Compositepro,
Since this forum is by nature pedantic, check your last post. The eighth word should be "their".
I would suggest a further improvement to WoodBarn's sentence: "Procedures which may confuse employees in doing their jobs must never come into effect." The comma is unnecessary and confusing.
Procedures
whichthat may confuse ...That should be used whenever the following phrase is a restrictive phrase.
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
http://en.wikipedia.org/wiki/The_Mother_Tongue
If you do buy the book you may find the chapter on obscenities interesting since it tries to actually explain why there are '7 words you can't say on TV' and why they're considered 'dirty'.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Technically, the glass is always full.
Funny enough, I've noticed a few lawyers that have issues with this in written communication. It is probably all the same to them though.
f-d
¡papá gordo ain't no madre flaca!
