Hard Drive RPM Control?
Trying to create a feedback system to read the hard drive RPM and then set the RPM to a specified value.
Any ideas on how to set the rpm of the drive?
RE: Hard Drive RPM Control?
TTFN
Wouldn't you compare the measured vs. desired and command the servo to increase or decrease the rate as appropriate?
TTFN
Dan - Owner
http://www.Hi-TecDesigns.com
TTFN
Chris Krug http://krugtech.com/
Maximum Up-time, Minimum BS
