Configurations working with equations
I have an equation driven assembly.
Part A = Total height - Part B sketch (config1)
Real Equation--->"D2@Sketch1@PartA.Part" = "D1@Height"-"D1@Sketch13@PartB.Part"
This works out great.  But when I change the config of Part B (config2, a different size), it still uses the size from config1 for the equation.  My part size doesn't change for the configuration.
How do I fix this?
Thanks!
RE: Configurations working with equations
Thanks for the confirmation.  I made a new part and added it as part of the configuration, and suppressed the other part.  Hopefully this will be 'fixed' someday, and we can eliminate a few steps.
Did you tried Design Tables?, I think will work much better.
