What schedule pipe to weld in fittings?
I am designing a plant to make emulsions. Much of the piping can be 2" and schedule 10 stainless steel welded pipe will be convenient for much of the piping. However, we have to feed three ingredients using quills and such things as an in-line pH meter needs to be installed. So, I need to install pipe couplings for the quills and incorporate the pH probe and my intuition says schedule 10 is too flimsy for this. So, what schedule should it be? Many thanks in advance.
RE: What schedule pipe to weld in fittings?
the responsible engineer needs to use the appropriate piping code (B31.3, etc.) for the design of piping components. asking for which schedule to use implies you are not the responsible engineer; hence, the recommendation.
good luck!
-pmover
If you use thread-o-let type self-reinforcing threaded branch connections for your quills and pH probe. and you follow the manufacturers' instructions, you will need to fill the entire weld bevel. Since the fittings are 3000# rated, that's a LOT of weld. On sch10S pipe, you'll end up with a lot of shrinkage- the pipe will become a banana. You'll get less on sch40S and less still on sch80S.
Of course you can also use reducing tees and avoid all this.
Which method and which schedule you choose will depend on many things. Important amongst these is the length of the pipe line, which will determine the cost of pipe versus labour to weld it etc.
