Shortcuts to repeat same command ?
I am trying to find a shortcut to repeat the same command.
For example, if I 'select circle' and then 'draw a circle'. I would have to go back to the toolbar and select it again. What is a shortcut to not do that?
Autodesk Inventor has a shortcut that you can press 'enter' or right click and select repeat (command).
I am using 'CATIA V5'.
If anyone knows how to unlock a shortcut similar to Autodesk. I would really appreciate it.
RE: Shortcuts to repeat same command ?
Easy way to do similar to what you described, double left click on the circle icon and it will stay active until you explicitly cancel the command.
The exact same functionality is Edit > Repeat which is assigned the accelerator CTRL+Y by default.
Certified SolidWorks Professional
Does Anyone know how to do the same thing (keep command active) when Sending them from the Command Line?
Quote (cscistudent):
I look into that next time I use an Autodesk Product which hopefully for me isn't too soon. But Really it'd be nice to know that as well but you probably already posted a Query there as well.
"It's not the size of the Forum that matters, It's the Quality of the Posts"
Michael Cole
Boston, MA
CSWP, CSWI, CSWTS
Follow me on !w¡#$%
@ TrajPar - @ Shweep
=   ProE       = SolidWorks
