Textbook on trusses.
What is the best book on trusses, that has the answers to the problems? I have the small "Simplified Design of Roof Trusses for Architects and Builders", by Parker, 2nd edition, 1941, 1953; which I like, but it does not have the answers to the problems. [b]
RE: Textbook on trusses.
For general truss analysis, a good structural analysis text will have what you need.
For general truss analysis, would you have a recommendation for a good structural analysis text (with answers)? Thx.
The forces may be the same - but how you handle them can be quite different.
http:/
Michael.
Timing has a lot to do with the outcome of a rain dance.
How do you download the book? I don't see that option in the link you provided.
Michael.
If you look up Grade 60 rebar in current data, it shows the YIELD strength to be 60,000 psi. Are we to ignore the Handbook's numbers?
Michael.
