Ask inspection method plate exchanger
We have plate and spiral type exchangers at PVC plant, presently we are having visual inspection of only visible area external for the same. By using your valuable experience and knowledge kindly if you could help me to define the required inspection scope for a plate and spiral type exchangers.
Thank you
Thank you
RE: Ask inspection method plate exchanger
