VALVE for flows in two pipes
I have two pipes of equal diameter running alongside each other, as part of different circuits. Sometimes the fluid inside each pipe will be flowing in 'opposite' directions and sometimes the fluid in each will flow in the same direction.
Is there a valve in existence that I could use to stop the flows in both pipes whenever the flow directions (and presumably the pressures causing these flows) are 'opposite', but allow both flows whenever the flows are in the same direction?
RE: VALVE for flows in two pipes
Try to draw what it is exactly you want to achieve in a schematic, and bring that to your hydraulics supplier (or post it here). I think that's the best way to get a result.
NX 7.5
Teamcenter 8
Possibly Pilot Operated Check Valves then...
I think you could get there with a pilot operated valve in each line, and some check valves to control the pilots from each process line.
Slightly more difficult if you cannot allow cross-contamination via the pilot circuit.
Two rotary gear or vane motors/pumps, with the shafts coupled together, will do what you want. One fluid through each positive displacement section. They could be in one housing, or if cross contamination is not allowed, two separate housings with the shafts coupled externally.
The pressure drops would be quite high, guessing 50 to 200 psi to get them turning.
Other than that, I can only think of two flow meters, electrical controls, and a solenoid valve in each line to shut things off.
