Process monitoring systems
Hi all,
I need to find a process monitoring system capable of monitoring up to 30 injection molding machines.
I will not be using cavity pressure sensors, just need to help monitor viscosity related changes, cycle times, production numbers including scrap, ect...
The only system I am familiar with is RJGs edart system. I know there are many out there and I would much rather take advice from you guys with the real experience other than a salesmans.
Thank you all in advance
